jobs keep stopping - nginx
Discussion in 'Webmastering & Programming' started by multi-tasking_guy, Feb 10, 2018.
  1. multi-tasking_guy
    multi-tasking_guy n00bie
    61
    Jun 16, 2017
    I am using nginx as a reverse proxy. Everything works normal but after a couple days my website stops working.
    even if i reboot, it doesn't work. I have rebuild the server again, but again in three days it stops working,
    i think it has something to do with the hostname and jobs
    In the nginx server everytime i exit the bash it says "you have stopped jobs
    [1] Stopped /etc/nginx/nginx.conf
    [2] Stopped /etc/hostname
    i think it has something to do with that above jobs
    anyone have any idea?
  2. ChristianVirtual
    ChristianVirtual [H]ard DCOTM Mar 2016,Aug 2017
    1,870
    Feb 23, 2013
    How do you start the server ? Sounds like not as a service or backgrounds task and the moment you log off your shell you loose the server ?
  3. mwarps
    mwarps [H]ardness Supreme
    8,190
    Oct 6, 2002
    Those aren't commands. It looks like something may be attempting to edit those. That would be Very Bad (tm).
    Check your lastlog, your who, and your /var/log/auth.log to see if someone has gained access.
