Jetway A210GDMS-Pro / Silverstone SG01
casAZ
Hi. Need some help with my new SFF build. Kind of a noob build question, but since ppl in this forum have the Jetway MB and some have the SG01 case...I figured this is a good place to ask.
Some of the pin connections were self-explanitory reading the Jetway manual...but not the on-board audio.
the SG01 front-panel audio wires (there are 5...two of which have a second connector...so 7 total) are labeled:
ground, mic-in, mic-power, R-out/R-ret, L-out/L-ret. The R-out and L-out daisy chain to a respective 'ret' connector.
The Jetway audio/mic header pins (9 total) in the manual are labeled:
1-Aud_Mic_L
2-Aud_Gnd
3-Aud-Mic_R
4,6,10 all labeled NC <-- noob question...what does NC stand for ?
5-Aud-Frout_R
7-no label
9-Aud_Frout_L
8-no pin where 8 should be
So the ground is easy. R-out and L-out are ok...except not sure where the second connections R-ret and L-ret go ? And the audio wire labels mic-in / mic-power don't really match the pin labels Aud_Mic_L and Aud_Mic_R...
Thanks for your help.
cas
i've looked that over and am stumpped too. i suggest getting onto the jetway website and seeing if the manual there is any better.
It doesn't have the manual for the A210GDMS-Pro.
