Jetway A210GDMS Fan control
tempoct
Hi,
It seem like I could control 3 fans on this board (CPU, Sys fan 1 and Sys fan 2). Connected fans to any of the on-board connector seem to read RPM correctly but doesn't have any ability to control them.
I'd like to lower rpms of the fans to reduce noise. I use to be able to do this by Speedfan on other board but so far no luck with this one. It would be very nice if I don't need to use external fan controller.
Any thought?
Never had a board where Speedfan actually was able to adjust the fans. Send in your board info and hope the creator updates it, but I would not count on it.
If anything is really bothersome, you may want to try a Zalman fan mate or external fan controller.
My old A7N8X Deluxe would work till about 60% fan speed before just completly resetting. My Jetway has no control over the fan speeds, so im assuming its just a different sensor not recognized by speedfan.
