HardOCP News
[H] News
- Dec 31, 1969
It took these guys a bunch of tries to get it right but, by the end of the video, they finally got the thing working pretty damn good.
Not to be a stickler, but I'm always disappointed when "Jet" turns out to be a fan. I guess they call them jets because hobby planes use these electric ducted fans in place of fuel burning jets.
Probably gets less attention if they called it "Fan on a snowboard"
Wow, that thing looks heavy! If they made the frame out of aluminum or printed material, I bet it would have performed a little better.
There is no jet on a jetski either.
The real issue is that you associate jet with having to be a fuel based combustion engine that is on a turbo jet or some other type of air craft. Jet propulsion by itself is just thrust cased by a jet (stream) of matter in the opposite direction that you wish to move. A jet ski does this by shooting water backwards and moving you forwards. A turbo jet does this by pushing air, however it needs large combustion engines to achieve the amount of airflow needed. Something like this can be done with a electric fan to create a jet of air large enough to move you.
