switchg3ar
- Jan 1, 2007
For some time now I have been looking through various posts about workstations, case modding and other various projects. I have tried a few mods including a custom liquid cooling box. But now I want to apply what I have learnt to a jerker desk knock off (kind of). Maybe this doesn’t fit here but so many people rave about the jerker desk.
This is my inspiration
I'm halfway through the project so I will post what I have, It has similar dimensions to the jerker it's 34.5 deep by 57 inches wide.
I didn't start taking pictures throughout but here is what I have.
This is a corner of the desk that has be rounded. It's MDF that has be sliced every 1/2 inch. Then using a head gun I was able to bend the MDF to make that radius. It's painted white because I'm planning on putting lights in there. When all is finished you won't see the paint.
This is a better shot of how it was cut.
This is about halfway through, it's still missing glass, LED lights, grout, clear coat and the legs.
The top consists of Maple 3/4 inches thick. To make it appear thicker a thin strip has been glued to the top to give it the appearance of 1.5 inches thick. Then to create the curves for the top a bottom piece has been glued sideways. Then using a jigsaw to cut the radius.
More details I originally wanted to use glass squares but since I was going to use a glass top I decided why not stone. So I had to prep the MDF so I scuffed it so that the glue would bond better.
The maple is only 3/4 inch thick and I wanted to go with 1/2 inch thick glass. So I needed to beef of the support so I took 1 1/2 stripe and glued it to the top. Later I will router out a square channel so the glass can be inserted.
How this all started off is I just wanted to cut a larger piece of square MDF for my rig to sit on. Then I decided why not make the sides curved. I was jealous of seeing how big the jerker desk was, and I wanted something bigger.
