selling some items to help pay for doctor visit concerning ear problem i have had for 3 weeks. if you know of a good ear specialist in california please send me a PM. am at the end of my candle with this pain
triple 120m black ice pro with medium speed yate loons . and fan gaurds . may have bent fins easy to fix . paint may be scratched
removed from sale due to damage to radiator even though it never leaked
double black ice pro (blue flake is best description i can give for color ) , no fans . does have a few bent fins which is easy to fix paint has minor scratchs
$30 dollars
rotron 12 volt pumps . one tested and other never been tested. may have noise dont remember .
$40 dollars each
mcw6002 waterblock with tbred mount (missing springs for mount)
$20 dollars
Fans and Fans and Lots more Fans
Scythe SY1225SL12HPVC Slip Stream 120x25mm PWM Adjustable Fan
Model: SY1225SL12HPVC
Product Details:
New from Scythe the Slip Stream 120 PWM Fan Series!
Features:
PWM Adjustable:
By adjusting the controller on PCI Bracket, the band of PWM range can be set as below.
This switch can be attached into any empty PCI Slot.
Small Center Hub & Wide Blade Type:
By reducing the dimension of the center hub and enlarging the blade surface area, high airflow is generated at a low RPM.
In Order to take advantage of PWM function, please use the motherboard with PWM features build-in.
PWM function will not work if the fan is connected via 4 Pin peripheral connector or connected to 3-Pin fan port. In this case, the fan will spin at the maximum speed.
Connection to any third arty market fan controller with 3-Pin port, PWM function will not work but fan speed can be adjusted by the fan controller.
Specifications:Band Range RPM Noise Level Air Flow
Maximum Band 740 (±25%) ~ 1900 (±10%) 9.8 ~ 37.0 dB 37.15 ~ 110.31 FM
Minimum Band 470 (±30%) ~ 1340 (±10%) 7.05 ~ 27.3 dB 23.0 ~ 76
$8.00 dollars
SY1225SL12H-P 120x120x25 500 (+200)rpm - 1.900 (±10%) rpm 7.5 ~ 37.0 dBA 24.50 ~ 110.31 CFM 0.51 A
Slip Stream 120 PWM
The new Slip Stream PWM 120 mm fan can work by using a PWM enabled motherboards,which are automatically controlled.Slip Stream 120 PWM fan offers the same features such as the Slip Stream and a silent user can obtain more airflow without sacrificing in noise level.
More Airflow
Compare to a standard 120 mm case fan available in the market, Scythe Slip Stream 120 mm case fan generates more airflow (Approximately 20~40% more).
4-Pin Peripheral Adapter Provided
To be versatile, this case fan comes with the 4-pin peripheral adapter.
$5.00
Brand
Scythe
Model
SY1225SL12LM-P
Spec
Type
Case Fan
Compatibility
Case
Fan Size
120mm
Bearing Type
FDB Sleeve
RPM
0 (+200)rpm - 1.300 (±10%) rpm
Air Flow
0 ~ 74.25 CFM
Noise Level
0 ~ 26.50 dBA
Power Connector
3-Pin (4-Pin Molex Adapter include)
Physical Spec
Dimensions
120 x 120 x 25 mm
Features
Features
Slip Stream 120 PWM
More Airflow
$5.00
Two Panaflo 120mm x 38mm (fbk-12g12l)
these are wired together for a dual 120mm radiator i had
$15.00 for both
Akasa Viper PWM
Application: PC case or heatsink fan
Dimension: 120 X 120 X 25mm
Fan speed: 600 -1900 RPM
Max airflow: 83.63 CFM (141.75 m3/h)
Max static air pressure: 2.98 mm H2O
Noise level: 6.9 -28.9 dB(A)
Current rating: 0.17A
Voltage rating: 12V DC
Bearing: HDB (Hydro Dynamic)
Fan life expectancy: 50,000 hours
Connector: 4pin PWM
Product code: AK-FN059
$6.00
PAPST 4312M 12VDC 119x119x32mm
Manufacturer: ebm-papst
Part No: 4312M
RoHS: Yes
Fan Rotation: Clockwise
Bearings: Ball
Family: 4312M
Operating Frequency: N/A
Voltage Rating: 12 V
Category: DC Fan
Termination: Leads
Housing Material: Polybutylene Terephthalate
Operating Input Voltage Range: 6 to 15 V
Mounting: Flange Mount
Nominal Speed: N/A
Noise Level: 39 dB
Line Current: N/A
Power Rating: 2.6 W
Maximum Airflow: 82.4 CFM
Operating Temperature: -20 to 75 °C
Dimension: 119 x 119 x 32mm
minor chip in blade dont think it will affect it, bare lead meaning it needs a connector to use it. item is used condition
$15.00
items sold
Lian Li PCQ11B (modded) $40.00 dollars sold
Lian Li PCQ07R sold to no_control
terms and conditions
price doesnt include shipping
no returns , all sales final
no guarantee of overclocking
please reply to thread when you send a private message
Jen
$30 dollars
$40 dollars each
$20 dollars
Product Details:
Features:
PWM Adjustable:
$8.00 dollars
Slip Stream 120 PWM
More Airflow
$5.00
Brand
Scythe
Model
SY1225SL12LM-P
Spec
Type
Case Fan
Compatibility
Case
Fan Size
120mm
Bearing Type
FDB Sleeve
RPM
Air Flow
0 ~ 74.25 CFM
Noise Level
0 ~ 26.50 dBA
Power Connector
Physical Spec
Dimensions
120 x 120 x 25 mm
Features
Features
Slip Stream 120 PWM
More Airflow
$5.00
$15.00 for both
Akasa Viper PWM
Connector: 4pin PWM
$6.00
Part No: 4312M
RoHS: Yes
Bearings: Ball
Family: 4312M
Category: DC Fan
Termination: Leads
Nominal Speed: N/A
Noise Level: 39 dB
Line Current: N/A
Power Rating: 2.6 W
$15.00
items sold
Jen
