JEDEC Previews Next-Generation DDR6 DRAM
Beaver LongTail
8-D
“The following features reflect current JEDEC DDR6 development plans rather than a finalized standard, and are subject to change through JEDEC's development and approval process:
Increased Performance
  • Higher bandwidth: Improved data rates and a wider bus will combine to increase bandwidth more than 50% at introduction, with further bandwidth increases as data rates increase. This bandwidth target is distinct from a claim of equivalent improvement in application performance.
  • Higher data rates: DDR6 RDIMMs move beyond DDR5's 9.2 GT/s to a data rate that will start at 12.8 GT/s with a roadmap extending to 14.4 GT/s and beyond.
  • Wider bus: The data bus expands from 64 to 96 DQ, a 50% increase in data bus width.
  • Pseudo-channel architecture: DDR6's planned architecture organizes memory access into pseudo-channels to support higher bandwidth per DRAM package. It is intended to provide greater configuration flexibility for system reliability and more efficient data movement.
  • Higher bank availability: 2X bank count and improved refresh boost data bus efficiency, enabling system performance at higher speed grades and higher capacities.
Higher Capacities
  • Higher DRAM density: Support for up to 128 Gb DRAM die density.
  • Efficient capacity scaling: Optimizations for die stacking in DDR6 packages delivers more density per package footprint.
  • Compact module footprint: A significantly narrower 74 mm DDR6 module length, compared with 133 mm for DDR5, is intended to help accommodate higher system memory density.
Reliability
  • Flexible reliability: Support for multiple system error-correcting code (ECC) implementations will allow system designers to balance cost, power, and reliability at the system level.
  • Built for the data center: Interface optimized for high-capacity modules with configurations oriented to general purpose compute as well as AI inferencing and agentic AI, which demand more capacity and performance close to the CPU.
Energy Efficiency
  • Improved performance-per-watt: DDR6 targets significantly improved performance-per-watt versus DDR5 through a change to VSS-terminated IO and data-center-focused low power modes.
Form Factors
  • Breadth of form factors: DDR6 is being defined across multiple form factors—potentially including RDIMM, UDIMM, and CAMM to serve a broad range of applications while balancing reliability, performance, power, and cost.
Christopher Cox, Chair of the JC-42 Committee for Solid State Memories"As AI and data-intensive workloads continue to drive system requirements higher, DDR6 is being designed to deliver meaningful advances in memory bandwidth, capacity, and reliability. The collaboration of JEDEC member companies is helping create a next-generation memory standard that balances performance, power efficiency, and scalability across a broad range of computing applications."
Mian Quddus, JEDEC Board of Directors Chairman"JEDEC members gain early access to pre-publication proposals and insights into active projects such as DDR6. We welcome interested companies worldwide to join JEDEC today to help shape the future of standards for this dynamic industry."“
Source: https://www.techpowerup.com/354995/jedec-previews-next-generation-ddr6-dram
