JBOD with Areca ARC-1680x
dshor
have anyone used he Areca with JBOD mode? (windows)
what happen when you and a new disk ? do you need to define it as a Pass-Through to the OS, or that is the default option ? if you replace a disk in the same port will it be in Pass-Through if the original one was too ?
do you need to reboot the computer at ant stage ?
Thanks
I use my Areca ARC-1220 now in JBOD mode, after the pass-through disks kept failing. That means: on every timeout the Areca controller will remove the harddrive from the pass-through configuration; you would have to recreate it everytime. That was not what i wanted, so i now use JBOD mode. I've not yet had any issues since then.
To use Areca in JBOD:
- enter RAID setup by pressing Tab/F3 when the Areca BIOS bootstrap tells you so
- remove all RAID sets including any passthrough disks
- go to "raid functions" menu and choose "JBOD/RAID mode" and set it to JBOD instead.
- go back to main menu and press F10 to reboot
Yea, or you can do it through the web management console.
System Controls -> system configuration.
Thanks,
so you basically turn the adapter in to a plain HBA ? no option to have RAID on some of the disk?
are Areca going to have a fix for that? I want some disks to be in a RAID array, and some in pass-through (formatted on a plain windows computer)
Then you do not want JBOD mode, as that transforms the whole controller in a simple HBA and not a RAID controller.
If you want both pass-through disks and RAID arrays, then you cannot do that in JBOD mode; but you can in RAID mode.
Note that you can enable write-back on passthrough disks, but be careful as that could corrupt them if you do not have a BBU.
what about the timeouts in the pass-through disks ? I understand that this mode was king of useless for you because of that.
Will the write-back cache also work in JBOD mode? Does the controller write a signature block to the disks in pass-through mode like 3ware controllers in single disk mode or do they pass the plain disk?
What exactly happens to pass-through device on os level in the case of a device failure?
Thank you!
As i believe:
JBOD mode: behaves pretty much as single disk HBA
RAID mode with passthrough: disks can fail and be not visible at all, due to a simple bad sector/timeout
The write-back can be enabled with passthrough disks; not sure about JBOD mode. I have write back disabled, and you shouldn't enable it without BBU.
As i believe:
It wont just timeout cause its a passthrough disk.
What drives are you using?
Turn off APM
Well at least if a timeout occurs in passhtrough mode, that disk will be removed and be in a "Free" configuration; i would need to reboot the system, go into Areca RAID and create the pass-through disk again. This procedure can be done with the Areca-CLI also, without rebooting. But it wouldn't be necessary on a real HBA without RAID.
The Areca ARC-1220 is currently in use in my backup fileserver and doesn't use APM or spindown. It uses Seagate 7200.10 500GB non-RAID edition disks. Previously these have been in my main array on HBA instead and worked correctly for years. These were the disks i used when i started with ZFS even before ZFSv6 was integrated into FreeBSD. Edit: actually i used my older 320GB SATA disks with first ZFS i realize now, but i retired these disks due to power reasons.
But honestly, i consider removing the Areca controller and getting a true HBA instead. The potential of this card is kind of wasted, and a true HBA actually works better for me. I've been really happy with my SuperMicro USAS-L8i; simply works great. And i did have disks with timeouts, which shows kernel messages, but didn't degrade the array. I didn't had a totally failed disk with ZFS yet.
