Java Zero-Day Flaw Under Active Attack
HardOCP News
[H] News
Today might be a good day to avoid websites with song lyrics. According to this article, people using Firefox or IE with the Java plug-in run the risk of being compromised thanks to an unpatched hole in Java. Chrome users seem to be safe for now.
Malicious hackers have pounced and are exploiting the flaw in the wild to launch drive-by download attacks. Virus hunters have spotted the attacks on a popular song lyrics Web site. Any visitor to that Web site with the Java Plugin for Browsers installed (Internet Explorer or Firefox) will get infected with malware.
wow that is bad, I am programming in java so no way I can remove java :)
Wow. That took a long time... first I've heard of such a java exploit... and java's been around for how long now?
This exploit has been possible for a while. As well as others in the past. I saw a demo a couple of weeks ago where a website could silently launch java and steal your private IP from behind a NAT router and displayed it on a web page. It worked on 3 of the 4 machines I tested it on. The 4th one had Kaspersky Internet Security and it seemed to block it. That was when I removed Java.
Java doesn't get installed on any machines I work on — it's that simple. In 2011, I intend to get rid of Flash entirely. I don't anticipate it being a problem.
2011 is going to be awesome.
You're doing it wrong Buzzy. I hear great things about C#.
I'm pretty sure that all you have to do is disable the Java browser plugin
The last sentence of the article:
Disabling the Java plugin is not sufficient to prevent exploitation, as the toolkit is installed independently.
I just realized that I have had my new computer for 14 months now, and have never installed Java. I guess I never needed it!
Wins what? This is not a browser issue. This is Java. It doesn't matter what browser you run this swiss cheese plugin with.
:rolleyes:
Did you even read the first post? Lmao.
It even says in the article "Internet Explorer or Firefox"
No Chrome doesn't win. :p
:rolleyes:
I don't care what the first post said. :p
It is still a Java issue, not a browser one. Remove Java, problem solved.
This morning I saw on the java site they have java 6 update 20. I decided to install it on my windows 7 pc here at work and during the install the pc crashed. After reboot I tried again and it installed. Later though I decided to remove it and during the uninstall the pc crashed again. So whatever it's worth be advised.
I know I'll have a few machines here in the office which will require java to access some web sites. But I think I'm going to start removing it from all machines as well and only install on an as need basis, block java in the firewall and add exceptions as needed.
Java 6 u20 fixes this issue btw. They were informed of the issue back in December and the patch was included in the last update. http://www.oracle.com/technology/deploy/security/critical-patch-updates/javacpumar2010.html
AFAIK, there is not Java 6.20. 19 was the last update, and Secunia still lists it as a 4 out of 5 security hole. I'm not a security pro, but it doesn't seem very safe to use. Let's hope all seeing eye fixes this issue PDQ....if not, I can live without Java in my browser.
You needed to click the links inside of the original link I gave which was just links to which upgrade you should take depending on what version of Java you already had installed. 20 has been out since at least wedensday. http://java.sun.com/javase/downloads/index.jsp
BTW, thanks for the link. When i looked at the first link, yesterday, I only saw a link for U19....though maybe Sun was offering a patch to u19 that only replaced the patched parts.
For whatever reason, Oracle hasn't pushed it out via the jre update program and I guess Secunia hadn't updated their database yet and/or rescanned on my system, since it listed it as fully patched.
Anyway, thanks again....hope everyone else sees this and patches.
