Java Thread making
Aeren
Hi everyone!
I tried to make a Thread, but it doesn't work.
I have a class called NetMyThread, which implements Runnable.
Has a: private Thread myThread; as a variable, which is initialized in the init as follows:
Code:
myThread       = new Thread( this ); (init is called from the constructor)
myThread.start( );
the run function looks like this:
Code:
  public void run( ) {
    try {
      for (int i=0;i<5;i++){
        Thread.sleep( time );
        System.out.println("blahblah");
        differenceEngine( );
    } catch( InterruptedException e ) { System.out.println( e.toString( ) ); }
I can't see anything written out on the console. What's wrong with my code?
Thanks!
Aeren
when debugging, it is often useful to just catch everything with a catch(Exception) and then inside the body include e.printStackTrace();
Here's one of my working threads:
Code:
public class Blargh extends Thread {
	public Blargh() {
		System.out.println("Blargh instantiated, yarr!");
	public void run() {
		System.out.println("Thread started!");
		while(true){
			try{
				System.out.println("Blorples");
				Thread.sleep(1000);
			catch(Exception e){
And here's how I call it:
Code:
blah = new Blargh();
new Thread(blah).start();
Well I copy pasted your code and the good news is that it runs fine. So the problem lies elsewhere. If you need more help just post up more code.
Cheers!
Cheers!
It runs for me as well, but it doesn!t write blahblah out at all. Did i do it right with the System.out.println?
Well yes, what I meant to say is that the code works fine for me. I copy pasted it and when i run it I can see the Thread working. Thus your trouble is something else that is not in the code you gave us.
