java: reading files from inside a jar file
Desova
i'm trying to read in and write to some text files from within a data folder in a jar file.
using the this.getClass().getResource("./data/file1.txt");
returns an url, but i cant figure out how to link that from the IFileWriter / FileReader classes, or how to pass a string into them that works.
any ideas?
java.net.JarURLConnection
will probably help you, you can use it to get Streams from the files inside, however it is unlikely you will be able to write to those files, as this would involve changing the jar itself.
