Java Problem
p3n
We were told to write this program which takes the date and tells you which day of the week it is:
Code:
import java.util.*;
import java.text.*;
import java.io.*;
class FindDayOfWeek {
	public static void main( String[] args ) throws IOException {
		String inputStr;
		int year, month, day;
		GregorianCalendar cal;
		SimpleDateFormat sdf;
		BufferedReader bufReader;
		bufReader = new BufferedReader(
					new InputStreamReader( System.in) );
		System.out.print("Year (yyyy): ");
		inputStr = bufReader.readLine();
		year     = Integer.parseInt(inputStr);
		System.out.print("Month (1-12): ");
		month    = Integer.parseInt(inputStr);
		System.out.print("Day (1-31): ");
		day     = Integer.parseInt(inputStr);
		cal = new GregorianCalendar(year, month-1, day);
		sdf = new SimpleDateFormat("EEEE");
		System.out.print("");
		System.out.print("Day of Week: " + sdf.format(cal.getTime()));
Then change it so it only had one input, easy enough but no when the input is in mm/dd/yyyy format, you need to remove the slashes to get it to work, I thought I could but The prog doesnt work properly, anyway this is what ive tried:
Code:
import java.util.*;
import java.text.*;
import java.io.*;
class FindDayOfWeekOneInput {
		String inputStr;
		int month, day, year;
					new InputStreamReader( System.in));
		String monthStr;
		String dayStr;
		String yearStr;
		System.out.print("Enter the Date mm/dd/yyyy: ");
		monthStr = inputStr.substring(0,2);
		dayStr = inputStr.substring(3,5);
		yearStr = inputStr.substring(6,10);
		month = Integer.parseInt(monthStr);
		day = Integer.parseInt(dayStr);
		year = Integer.parseInt(yearStr);
		cal = new GregorianCalendar(month, day, year);
Is there some easy way of doing this, am I on the right track ?!
I've modified the prog to print what the strings contain and it showed '02262004' .. which should work .. aahhh!
help!
*edit this soulda been a reply close plz!
from first program:
from second program:
does the order have anything to do with it? i would imagine so.
It's amazing how things break when you're not following the API...
The other option to break apart the string of the format mm/dd/yyyy, where mm and dd can be 1 or two digits, is use a StringTokenizer and tokenize on "/".
