I discovered a source of instability for all SLI systems. Apparently, Java doesn't like SLI. What I was experiencing was any time I tried to load a page that had Java on it, my browser would lock up (Firefox and IE), the screen would revert to 640x480 with like 8-bit colors, then the machine would lock hard. A reset would get reboot the system, but the next time i tried to run any java app, I'd get the same thing. I tried uninstalling java and every time I tried, I'd get a BSOD followed quickly by a reboot. When trying to reinstall java, I got the same thing.
If you're getting this, do the following:
1. Start->Control Panel->System
2. Click the Advanced Tab
3. Click the Environment Variables button
4. Click the New button
5. For Variable name:_JAVA_OPTIONS
6. For Variable value:-Dsun.java2d.d3d=false
7. Click OK button.
8. Click OK button.
9. Click OK button.
I did it in the bottom section, but if you only have one user on your system, it's probably much safer to put it on the top.
That fixed it. Now java runs fine. Hope that helps somebody.
7. Click OK button.
8. Click OK button.
9. Click OK button.
