Java Help - Counting White spaces
lil layzie
I'm trying to count how many white spaces there are in this particular string.
The string is "say some thing"
Which would mean there is 2 white spaces.
Code:
int count = 0;
String aString = "say some thing";
	for (int n=0; n<aString.length();n++)
		if (aString.charAt(n)==' ');
		count++;
I think there is a problem with my aString.charAt(n)== because it is adding 1 to count for every character, not just a whitespace.
How do i define a white space so i can make an if statement.
First delete the semi colon at the end of the if statement. Then try using Character.isWhitespace(aString.charAt(n)) instead.
... isnt their also something like string.length(); too?
Forgive me I'm a bit of a newbie.. and I cannot remember the syntax perfectly but I know we've used something like that in our classes :)
