Java GUIs
LBJuice
I really like the Visual Studio Framework. I'm building a java application and I want my gui to be in a class called "Form" and I want my main method to be in a class "Program" so I can write a simple line of coding saying like Run(Form);
Form Class
public class Form {
private javax.swing.JFrame container;
public void Form() {
InitializeComponent();
public void InitializeComponent() {
this.container.setName("Frame");
this.container.setSize(500,500);
this.container.setDefaultCloseOperation(javax.swing.JFrame.EXIT_ON_CLOSE);
this.container.setVisible(true);
Program Class:
public class Program {
public static void main(String[] args) {
// what would I need to write here to launch an
// instance of Form and for it to be displayed?
it seems like it'd be simpler for your Form class to extend javax.swing.JFrame, then in your main method just put
new Form();
also, please use
Code:
 tags in the future.
anyway this is what you'd get if you put everything in Program.java
[code]
import javax.swing.*;
		new Form();
class Form extends JFrame {
	// note constructors do not have a return type in java
	public Form() {
		super();
		this.setName("Frame");
		this.setSize(500,500);
		this.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
		this.setVisible(true);
