java, excluding numbers?
mikeE
im still learning java and i want to make a random number generator that exludes zero (0).
i asked my teacher how to do it but she has no clue .... -_-
we're learning how to generate random numbers
Code:
import java.util.Random;
public class RandomNumbers
	public static void main(String [] args)
	Random generator = new Random();
	for(int i = 1; i<=5; i++)
			System.out.print(generator.nextInt(5) + " ");
i'm trying to make a card game in java ... and i know that cards don't have a 0 card =(
thx, any help will be appreciated :)
if the RNG outputs numbers in the range [0,n] and you want [1,n], tell the RNG to give you numbers [0,n-1] and add 1.
likewise, you can return a random number in any range you want by using that same logic
ie. random number between 10 and 20
print random(10) + 10;
ie. print random(max - min) + min;
of course that can vary slightly depeding if the random generator includes or excludes the value sent as the parameter
Well, since the Random class's nextInt(int n) method generates a number between 0 and n, you should just add 1 to the return value to get a value from 1 to n+1.
Code:
Random rng = new Random() //automatically seeded with a 48-bit number I think
System.out.println(rng.nextInt(12)+1); //prints some 'random' number between 1 and 12.
Is that what you were looking for?
As a note, nextInt(int n) generates a number from (0, n] (0 inclusive to n exclusive, I forget whether I used the correct bracket for each though). This means that if you put in 12, it'd only generate a number between 0 - 11. Adding 1 gets you a number from (1, 12).
That would be [0, 12).
Nothing more to add otherwise, just figured I'd address this point real quick.
