Prometheusg
- Dec 19, 2006
I keep seeing this mistake in various threads mentioning the iPhone. Jailbroken does not mean unlocked. They are two completely different things.
Jailbroken means that you can install basically whatever software you want on the iPhone. Different backgrounds, skins, apps, whatever you want.
Unlocked means you can use it on any GSM-based network you want. For US customers, this basically means the ability to use it on T-Mobile.
Just putting that out there.
