iWill ZmaxD2 Graphics Card Question
hansn
Hi-
I would like to upgrade the graphics-card of my iWill ZmaxD2.
Some of the newer PCI Express x16-cards require extra power supplied by a 6-pin PCIe connector. The ZmaxD2 doesn't have that one (as far as I know).
Can I still somehow use a graphics card that needs that extra power supply?
Are there other limitations (besides size) I should be aware of?
Thanks!
Hans
most graphics card that require extra power come whith an molex to pci power adaptor if not you can buy one from almost everywhere and there might be some high temp problems depending on which g-card you go for
