{NcsO}ReichstaG
- Aug 13, 2004
What kind of drop in temperature can I expect to see if I get this over a D5 or AquaExtreme 50Z? :
1) Swiftech Storm Revision2 for Opteron 165
2) Maze4 GPU block for 7800GT
3) DFI EXPERT MAZE4 CHIPSET for my Ultra-D
http://www.dangerdenstore.com/product.php?productid=212&cat=46&page=1
4) BIPIII with YateLoons
In terms of price VS performance, is the Iwaki pump worth it OVER the DD D5 or the AquaExtreme 50Z?
Also, if I was to one day get this Iwaki pump, the WMD-R20RLT, how do I adapt it to work with a 1/2" ID systems?
-Thanks
Iwaki WMD-20RLT American motor pressure rated pump. 3/4 inch MPT inlet and outlet. 1/38 HP Motor output. 3100 RPM motor speed. 0.48 amps. Max flow 8.2 GPM. 378 GPH at 6 feet of head. Max head 14.0 ft. Max system pressure 9.95 psi
for a system that would include the following components (right now I don't have any of them but I am considering finally buying them in the near future.....)
-Thanks
