IVY I5 Graphics
AP514
Hey can IVY I5 3570K intergraded graphics run utube and other Videos ok ?
for some reason it is a bit choppy..
I5 3570K
Ga-Z77-D3H
8 memory
1024x768 res.
17" monitor
Set 512mb for IGP in bios should i up that ? default was 64...maybe i missed a driver upgrade ?
any help....would be great..
AP514
fixed.....Easy fix too.....Updated Flash player....Doh....
AP514
As you already figured out, yes ivy can quite easily handle youtube videos, including HD ones. Even Sandy IGP which is quite a bit slower can handle them without a problem.
Almost every actual IGP can handle hd videos, the problem was not the gpu.
