Ivy Bridge Core i{5,7} vs. Xeon E3
Stratagerm
In planning to upgrade the aged system in my signature, I'm trying to understand Ivy Bridge chip pricing:
Code:
                     Price    Price Intel
CPU                  NewEgg   Box   Tray   Core/Th   L3   GHz       TDP   Graphics   Unlocked
Core i7-3770K        330      342   332    4/8       8    3.5/3.9   77W   640/1150   Yes
Core i7-3770         300      305   294    4/8       8    3.4/3.9   77W   640/1150   --
Core i5-3570K        230      235   225    4/4       6    3.4/3.8   77W   640/1150   Yes
Core i5-3570         215      213   --     4/4       6    3.4/3.8   77W   640/1150   --
Xeon E3-1270 V2      348      339   338    4/8       8    3.5/3.9   69W   --         --
Xeon E3-1240 V2      266      261   250    4/8       8    3.4/3.8   69W   --         --
Xeon E3-1230 V2      245      230   215    4/8       8    3.3/3.7   69W   --         --
(Source NewEgg/Wikipedia/Intel)
Why on earth would anyone ever buy a Core i5-3570 or Core i7-3770 over a Xeon E3? I can see going for the unlocked Core i7-3770K, but not the Core i5-3570K.
I probably wouldn't have thought about the Xeon if not for lightp2's comment in another thread which was then seconded by slh28.
My budget is tight at the moment, so if I could find a Xeon E3-1230 V2 tray at the MSRP of $215, it seems like a no-brainer over spending $330 for a boxed Core i7-3770K from NewEgg. NewEgg's $15 premium over MSRP for the boxed Xeon E3-1230 V2 is annoying—it's interesting that of these CPUs the boxed E3-1230 V2 has the largest difference from MSRP. Does it seem like something's up here?
I don't care about overclocking, definitely don't want Intel Graphics before Haswell (unlike Ivy Bridge it's supposed to have OpenCL support), will make use of hyperthreading, and appreciate the lower TDP (and thus heat) of the Xeons. I prefer aftermarket coolers for lower noise and greater reliability and cooling, so the stock HSF with the boxed CPU means nothing to me.
I've actually got two machines to update, so once Haswell arrives when my cash situation will be better I'd probably go for an unlocked Haswell equivalent of the i7-3770K and use the E3-1230 V2 in the non-gaming rig.
Comments?
You have made a number of good points here as to why these Intel® Xeon™ E3's are a heck of a deal at their price point. There are a couple things in favor of the Intel Core™ i5's and Intel Core i7s that do help out people. If the processor has an IGP (Integrated Graphics on Processor) then you will also have accesss to Intel Quick Sync; which for digital encoding can be a big performance boost. Also with the unlocked processors you have the ability to overclock easily. So make sure you check that the motherboard that you have supports the Intel Xeon E3's before you buy one.
As far as tray processors go with don't make those widely availible to the public also in most cases they only have a 1 year warranty. For a company like Newegg.com to take on of these processors and sell it they are going to have to add some packaging to get it to you.
Simple answer: CPU support, as Christian stated. There are a miniscule amount of consumer motherboards available that have BIOS support for the Xeon.
Another factor is that having the IGP is a nice back-up in case your PCI-E GPU fails, so that you have a back-up to keep using your computer for just about everything aside from moderate to heavy gaming or graphics demanding productivity software.
With a good aftermarket HSF, you will really see little to no difference in operating temperatures between the 69W parts and the 77W parts, especially since you will not be overclocking.
If I had both the i7-3770K and E3-1270v2 laid out before me and could only choose one, I would go with the 3770K just for the simple fact I can then choose whatever Z77 motherboard I wanted and have that IGP in case I need it.
I have worked with E3-1230, this type of series are mostly use for server usage and not graphic intensive. I guess it all depend on the purpose of the computer, if your using for something not graphic intensive then go with E3-1230.
At first Quick Sync looked good:
Wikipedia said:
Quick sync has been praised for being very fast. A benchmark from Tom's Hardware showed that it could encode a 449 MB 4 minute 1080p file to 1024×768 in 22 seconds. The same encoding using only software took 172 seconds.
But then I saw these, which are deal breakers:
Wikipedia said:
Quick Sync, like other hardware accelerated video encoding technologies, gives lower quality results than with CPU only encoders. Speed is prioritized over quality.
Wikipedia said:
Quick Sync is not currently supported on Linux. At the moment Intel does not have any plan for implementing support although it has been considered previously.
The machine is dual boot, spending most of its time as a workstation running Linux, sporadically booted into Windows for games. Since I've discovered that ArenaNet checks Guild Wars 2 for WINE compatibility and has released patches specifically intended to address WINE, there's less reason to boot to Windows. And Steam for Linux is coming.
[snip]
Yes, if both CPUs were available at the same price everyone should get the i7-3770K—with the IGP and being unlocked, it's the more capable chip.
But they're not the same price. Right now you can pick up a bare Xeon E3-1230 V2 for $223—that's $107 cheaper than the 3770K from NewEgg. The 3770K is almost half again as much as the 1230 V2 (48% more).
The IGP as backup is simply a justification of the extra cost. It's being pitched the same way that extended warranties or Best Buy Service Plans. Do you buy those? Anyone who doesn't have a spare graphics card laying around can buy a $15 card if they want to have a backup at hand and still maintain significant savings.
Of course if you keep the budget constant one should compare the E3-1230 V2 to the Core i5-3570K. For about the same price the Xeon gives you Hyperthreading and more L3 cache while sacrificing the backup IGP and good overclocking.
Now the motherboard issue is significant but not necessarily a deal breaker. A quick survey shows that low end Z77 mobos start off about $60 cheaper than low-end LGA 1155 server mobos, so it's possible that all the savings from the chip would get eaten up by the motherboard price. But according to this thread, apparently some Z77 motherboards support Xeons so a server mobo may not be needed.
Back in the day I was one of the many running dual overclocked Celeron 300s on an ABIT BP6. From a bang for the buck standpoint it was by far the best system I've ever had. It had great performance at a great price.
For a time it may have been the only option for dual socket 370 Celerons, which goes to show that while limited motherboard choice isn't good, all it takes is one decent motherboard selling at the right price to make it worthwhile.
Before I buy a Core i5 or i7 I just want to make sure there isn't a BP6-like situation where you can get great bang for the buck by doing something different.
1. Yes, if both CPUs were available at the same price everyone should get the i7-3770K—with the IGP and being unlocked, it's the more capable chip.
2. The IGP as backup is simply a justification of the extra cost. It's being pitched the same way that extended warranties or Best Buy Service Plans. Do you buy those? Anyone who doesn't have a spare graphics card laying around can buy a $15 card if they want to have a backup at hand and still maintain significant savings.
3. Of course if you keep the budget constant one should compare the E3-1230 V2 to the Core i5-3570K. For about the same price the Xeon gives you Hyperthreading and more L3 cache while sacrificing the backup IGP and good overclocking.
4. Now the motherboard issue is significant but not necessarily a deal breaker. A quick survey shows that low end Z77 mobos start off about $60 cheaper than low-end LGA 1155 server mobos, so it's possible that all the savings from the chip would get eaten up by the motherboard price. But according to this thread, apparently some Z77 motherboards support Xeons so a server mobo may not be needed.
1. Yes, you can spend 1/3 less and go with the Xeon. Again, the constraint is finding a decent consumer MoBo that will support a Xeon.
2. Good point, but having the IGP there is about convenience. No need to buy a separate backup GPU and have it sitting around collecting dust and taking up space. I do agree that getting an ultra-low cost GPU is still the more cost effective route. Again, the constraint is finding a decent consumer MoBo that will support a Xeon.
3. True, you essentially get an i7 non-IGP non-K model for the price of an i5-K. Again, the constraint is finding a decent consumer MoBo that will support a Xeon.
4. This is the biggest deterrent, imo. Just about all the Z77 MoBo brands I trust (Asus, Gigabyte, and MSI) do not have widespread, if any, support for the Xeon E3. Again, the constraint is finding a decent consumer MoBo that will support a Xeon.
;) :D
@Deja: Coincidentally I had the same question as the OP and checked Asus' CPU compatibility list last week for the E3-1230V2 and found that nearly all of their Socket 1155 boards claim to "support" the chip. But similar to the promise of VT-d support on Z77 boards, sticking a Xeon in an Asus board is not necessarily guaranteed to work. It's worth a shot though.
http://support.asus.com/CPUSupport/List2.aspx Search Xeon > E3 1230 V2
For gaming, the higher clock speeds that the 3570k can reach is significantly more important than hyperthreading. So for gamers who overclock, the 3570k makes much more sense than any Xeon.
Remember, the TDPs also include the IGP, so the 3570k and 3770k are rated at 77 watts with the IGP. This means that without the IGP, the 3570k and 3770k will have similar TDP ratings as the Xeons, which do not have an IGP.
Why 3570K? Because the free / simple OC is more useful to many.
The motherboards for Xeons will eat you alive...and tend to not be very...um...gamer friendly? They typically are short on PCI slots and don't let you tinker too much in the BIOS with anything performance/speed related. And they cost an arm & a leg.
