I ordered a si-97 and a Zalman 92mm fan from Newegg. What should I expect from this? Currently my CPU hits 65C under load with the case off. I am hoping that my cooling solution will at least take it down to the 50's under load. It runs around 44C at idle. Here are my system specs...
AMD Athlon 3200+ XP (it is an overclocked 2600+ at 2volts)
512MB Mushkin RAM
MSI KT6V motherboard
Does anyone have a similar setup? What kinds of temps are you getting? Thanks in advance.
Lyquist
512MB Mushkin RAM
Lyquist
