I've got an overclocking dilemma
Shadowfury957
(keep in mind im still a newb at computers) Hey, i just recently bought a dell vostro 200 mini:
http://configure.us.dell.com/dellstore/config.aspx?c=us&cs=04&kc=6W300&l=en&oc=brde2bf&s=bsd
because i needed a new comp fast, and i upgraded the processor on it to the e6550 at 2.33ghz. Now that i have it, i realize i want to overclock the cpu. So i think i need to buy a new motherboard for it so the bios isn't locked. I was looking around newegg and I found this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135050
If i got this ECS G33T-M2 motherboard, would i be able to put it in the vostro, have everything work normally, and be able to overclock my cpu (e6550)?
Or is there any other alternative to overclocking my cpu in this dell?
All help is highly appreciated! Thanks! :)
you might have to cut out the rear panel so the mobo outputs match up right. but really if you are wanting to over clock i would say put the original cpu back in, sell the vostro and piece together a system of parts you pick out. just my opinion though.
yep. admittedly things have changed, but thats the way i went with my first pc 1n 1998, after a week on the interet i decided i needed to overclock my dell, bought a new mb (abit bh6)and ended up with a $2000 pile of crap. start from scratch.
there might be some windows based stuff to overclock and/or up your vcore, like softfsb or clockgen. google.
Indeed, you should start from scratch.
Don't forget about the jumpers. Last I checked, Dell used a proprietary single plug for all of them, while AFAIK most motherboard manufacturers don't have a standard for the jumpers. You're going to be awfully disappointed when you throw your new motherboard in, only to find that you can't turn it on because the jumpers for the power button are incompatible with the plug for the case.
Plus, Dell uses shitty value parts. You probably have a crappy hard drive, crappy ram, crappy video card, crappy PSU, cheap case, etc. A faster processor and a new motherboard will not save you. If you did decide to get a new motherboard, and a new CPU, and somehow you got the jumpers working, you'd find that the case doesn't have good airflow, and that it's hurting your overclock.
Just sell the Dell on ebay or return it or something, and build one yourself. Frankendell is going to cost you a lot and you won't have that much to show for it.
