Ive got a problem, need some assistance. Puh-LEEZ! :)
ZenDragon
So I recently built a fancy new i7 Machine to replace a slightly aging but still performant Phenom II x6. However the Phenom has gotten an upgrade of its own to become a Hyper-V server running windows 2012 so far with only one VM running Windows Storage Server 2012. I also bought a 3Ware 9650SE 4LPML and 4 Western Digital RE4 1TB drives, which went on the trusty old MSI-890FXA with 16GB of ram. I set these up as a storage array on raid 5 (2.7TB total) with the OS running on a separate 7200RPM 1TB drive. The first VMs OS (Storage Server) drive is running on this drive, while the raid array is attached as a physical disk to the VM. I ran HD Tune from the VM and got about what I would expect a nearly straight line 138MB/s average with 10ms seek time. This is a sata-II controller mind you. I would say that is respectable performance, yea?
So the problem arises when trying to copy any large files from the host (2012 server with hyper-v role) to the VM (Storage Server 2012). Basically what happens is that it will copy for the first 3/4 of the file at 300MB/s+ and then all of the sudden just drop off to nearly 5MB/s. One of the first things I did was create a Private network in Virtual Networks in the Hyper-V manager and created a internal only network using vlan 2 (10.0.0.0/24) in addition to that I have a public network on my existing house subnet (192.168.1.0/24). Both have public IPs on the 192 subnet in additon to a private 10 subnet. When copying the share I am actually accessing it as (\\10.0.0.2\Share) which I would think would force it across the pipe however I am not ruling that out as a problem but its something that is necessary for the system to function so I need to find a way around that. By the way I get a pretty steady 90mb/s down from the storage array to I desktop with a solid sate disk, so I really honestly dont think it has anything to do with the network.
I considered buying another nic for performance reasons but it that doesnt seem like the problem. The fact that it is super fast but drops off at the exact same point in the copy evey time, seems like some kind of buffer thing to me.
What I have done is disabled Checksum offload values which I found as a suggestion on some websites while researching the issue. I will explain that in detail if you think it is relevant but I didnt seem to make a difference, so Im assuming its not.
This is my first real serious hyper-v box here and my first time playing with server 2012 so I am treading new ground here and could use some direction on where to look. My searches on the intertubes have not resulted in anything that worked. I want to bring up at least 4 other servers on this host, which it should be able to handle fine. I have played around with VMWare on some very serious quads with a CX-500, which wasnt even anywhere near in my leage of affordability for a home setup. Those were on fiber switches with iSCSI on giant 16TB raid arrays, with a whole new set of problems of their own of which speed was not one. My point is I have some experience, but not at all with home equipment so I m not really sure what is to be expected.
So just a quick run down of the specs:
1055T Phenom II
16GB of 1866 ram
1 Seagate 7200rpm drive OS and the file and storage OS VHD
4 x 1TB Western Digital RE4 drives in raid
3Ware 9650SE-4LPML Raid controller
1GB network all around (in theory) Im using a ASUS-R56Us built as a switch although I did borrow my buddies 1gb netgear 5 port router and it did not help.
So what do you guys think? Im at a bit of a loss at the moment as to what could possibly be wrong, I cant seem to find anything on the Internet.
Thanks so much in advance, I know of all the people I could ask you guys most of all would be helpful! :)
How many GB of your big file transfers before it hits the wall and goes to 5 MB/s?
How much ram do you have allocated to the guest vm (maybe this is a dumb question if Hyper-V does something smarter with ram allocation?)
And you are transferring from the the OS drive (in the host OS) to the raid array (in the guest OS) right? If so, my wild ass guess is you have too much ram allocated in the VM, copy is buffering to ram in the VM, until you hit the breaking point, and then bad things happen and kill performance to get the ram you've told the VM it has.
If you're transferring from the OS drive in the host to the OS drive in the guest, you could be running on a dynamically sized VHD and it needs to do some space allocation?
I'm not sure my wild ass guesses will be helpful, but i think answering the other questions may help someone who has worked with a system that's actually similar to yours ;)
The transfer is from the OS drive on the host (1TB standalone seagate drive) to a the VM. The OS partition of the VM is on the same drive however, the storage array that I am copying it to is a separate physical drive (4 disk raid 5 array) directly attached to the VM not using a VHD. I have 4gb of ram allocated to the VM. The transfer bottoms out at just about 2gb give or take, pretty consistently.
For what it's worth, I had the same issue and tried to track it down for weeks. Turned out to be a simple driver issue for my RAID card.
I've got the most recent driver I can on the host machine, Im assuming I dont really need to do that on the guest VMs as all the hardware is synthetic.
