Ive got a problem:/ Crashing...
mercedes-benz
When i open up the folding @ home window and try to switch it to fullscreen, the program crashes and burns.
can someone please help me? Thanks!
Just started folding for the [H]orde today!!!
It sounds like you're using the Graphical Client. It tends to be quite a bit buggier than console version. I'd suggest switching to the Console Client and EM3. If you want to use the Graphical though, I'd start with making sure that you're on the most recent video card drivers available.
Okay, just installed the console version, my graphical one just now started to crash after opening it. Im going to use the console version now. XD
Thank you for the welcomes!
yea...dont run both at the same time....that equal the bad.
