ITX overclocking mobo recommendations
AP2
Can someone recommend a cheap (under 100) mini ITX mobo with overclocking abilities? this will be for a 6700K.
Thanks!
Thanks!
Not going to happen. ITX Boards are quite expensive, even the cheapest ones that I wouldn't recommend are $115. One that I would recommend runs $180
Thanks!
sorry broseph, there are none that i know of. The cheapest good board i've used is z170i pro-gaming by asus the best OC board i used for a 6700K is Asus rampage Impact but its expensive and has U.2 instead of M.2
Thanks for guys! I realized that nothing exist at that price point.
