ITX case that fits a 5870?
I Dont think there is, But the Sugo SG07 & the Lian Li PC-Q08 should be out soon that I believe will.
or wait.. I think the lanbox (?) one might, but I dont think its quite for swale yet either
I had a hard time fitting a 5850 in an sg06. Not sure what mod would let the 5870 fit
the only one I can think of is cutting the front of the case structure to allow the card to stick through, but still be covered up by the front bezel.
Correct! That's the mod for nVidia cards(like my GTX260) but for HD5870, you have to cut opening for card and also trim or remove piece for two holes at the end too. I have no need for HD5870 for now as my GTX260 does everything I need to do but might have to upgrade to HD5870 when I need to play newer games at max settings. That was whole point of me getting SG06 rather than SG05. But then, I probably won't need HD5870 as only game I play now is L4D2 and plan to play D3 when it comes out if it comes out.
