coastertux
- Jan 20, 2004
What bitrate/VBR LAME should I rip my ITunes songs into after I have burned them?
Originally posted by leukotriene
You shouldnt.
You should leave them as AAC files.
Otherwise you are transcoding, which inevitably results in quality loss when transcoding from one lossy compression method to another (as in this case).
Because transcoding from lossy to lossy makes your songs sound like ass. Especially when the source is a 128kbps file.because being only able to have 3 copies of a song is a WONDERFUL idea.
In that case try using alt-preset-insane - the additional bits may help to reduce some quality loss.The reason I want to is so I can put the songs on my non-Apple MP3 player.
However, when I transcoded a 128kbps mp3 to a q-4 ogg I could neither hear nor ABX a difference. I suggest you try transcoding them yourself once, check whether you can actually tell a difference (which I highly doubt) and then make your decision.
I can hear a MAJOR loss at 192 AAC/LAME MP3/OGG from a CD and 128 MP3 to 128 AAC sounds a bit better then the MP3(?) but I still hear the loss. People have different hearing thats why you don't hear a difference but I have pretty good hearing (superman like if you ask my brother) and I can hear the difference.Originally posted by dravalier
There is a way to get around most of the DRM limitations provided you actually bother to look.
Do you know the size requirements for a lossless format?Originally posted by mcryptic
AAC files aren't lossless? That is ridiculous if you're paying $.99 a song, you should get full quality.
Originally posted by CrimandEvil
Do you know the size requirements for a lossless format?They would be impossible for download. Although I think they should be at a higher bitrate then 160 AAC, the lowess I'm encode is 192.
Anyways $.99 is seems about right for that, now if it was $1.99 or more then yes I would have to agree with you.
So you mean I can put AAC files on a non apple MP3 player?
i thought AAC was more like monkey's audio or FLAC, where it has compressed file sizes but does not reduce quality.
