iTunes... What?
I installed iTunes on my PC after reformatting it, and I ended up with itunes not willing to play songs it had played the day before. Basically, in playback, it gets skipped over, and I can't add album art. It's messing with my mind, and really fucking up my ipod. The songs are still playable by WMP11, and now 50 songs are missing when I try to re-add files. Dragging the file into iTunes won't add it.
Thanks in advance. Specs are in my sig.
There are known issues with iTunes and Vista.. I personally have not experienced any of these issues with my Vista install and iTunes, but, apparently they are there... soooo...
Try using Winamp, or Anapod, or Ephpod, and see if they solve your problems. From what I have heard, most of these issues revolve around syncing your iPod.. and I have read about some problems with album art as well.. but I would think that one of the app's I listed can get you by until Apple fixes the compatibility issues with Vista.... time will tell...
