turn off that aero stuff, and a lot of stuff that runs in the back ground your performance should go up.
"Every game I play runs as good (*well not good*) as it did on XP.
Thats SupComm, all the major Source titles, Battlefield 2/2142, Doom3, FarCry was a bit buggy but I worked around it."
Statement 2 violates statement 1.
In terms of how fast things run, unless you've bnechmarked the two, any statements about how well they run are pure conjecture. I'm sure the OP can google this topic. The general findings are that XP is about 5% faster and has fewer problems. Thus to the OP's question, is Vista ok for games? Yes, it is ok. XP is ideal. This is similar to how things were with 2000 vs XP. It will likely change with a service pack. Vista *!*!*!*!*!*!*!*!*!*!*!*!*!*!*!*!*!*!*!*!*!*!*!*!s ignore this sentiment however.
Aero doesn't make a difference when you play games. In fact, it's an improvement over XP with respect to the effect of eye-candy on overall performance.
http://www.firingsquad.com/hardware/windows_vista_aero_glass_performance/
"Sorry I don't need a benchmark to explain my gaming experience to me."
Well then your observations are irrelevant. It's akin to someone saying that their grandmother owned a **insert crappy unreliable car here ** and had no problems and thus it must be reliable.
"I play at all the same settings I did on XP and the game still runs great, and thats all I care about."
Great is subjective and can mean many things. Running 10% slower might be great to you, but I'm sure that most people would say that running slower is not great. Take the emotion away from you Vista purchase and you'll see that Vista as a gaming platform is not great. It is slower, has more hardware issues and game compatibility problems than XP. Those three things, in and of itself, would mean that Vista is not great for gaming.
I found this comparison of game performance in Vista vs XP. I didn't see anything ostensibly erroneous about the comparison, but I'm all ears...Show me a good study that came up with Vista being slower than XP. I'm talking about the same hardware and configuration settings on each machine.
As the author points out, this is largely an issue of driver performance, but that's not relevant in answering the question, "Which OS will run the game faster/slower?". Anyway, the article is dated late February, so I'm certain performance has improved, but as of that time, Vista seemed to be slower for the majority of games.
I wouldn't be surprised at all if that were the case. Even with those older drivers the performance gap was small enough that I personally wouldn't care.
Someone with an abundance of free time ought to do some tests that are up to date.
Not so great for me. Source lost about 60 FPS and Prey chugs (only two games I've tried so far). Both worked smooth as butter in XP
Which drivers were you using?
On my P4/3.2GHz & 8800GTS, I get slightly better FPS in CS:S with the 158 drivers than I did with whatever the current drivers were for XP in January 07. (granted, I might get better performance in XP using the current XP drivers, but I'm happy with 1920x1200, everything max & 60+ FPS.
i read the link with comparation,vista its not the correct choice.
i stay with xp,couple of months .maximu 6 months,and after this purchase to the vista.
If you can't tell it's slower then what is the difference?"Sorry I don't need a benchmark to explain my gaming experience to me."
I have thrown Supreme Commander, STALKER, Test Drive Unlimited, and BF2 at my Vista install and so far minus BF2 and that "your OS doesn't have the proper privileges" all of them have run smooth and without problems. Even STALKER. I even cranked SC settings all the way up without seeing a hitch in the frame rates.
I have a pretty beefy machine and so far my third Vista install is going good. I'm impressed so far. The first two resulted in a BSOD that never recovered and a failed hardware hard drive.
Agree, but with qualification. The user perceptions need to be observations made of a comparable combination of hardware and software titles used by somebody else in order to be meaningful when used as a predictive measure. So do the benchtests which generate the numbers.(So, the difference is not in whether or not you care, but in how useful your experiences are in answering the question of what others will experience. Numbers could do a better job...)
