Two nights ago I received a "USB Device is over voltage" message while booting. The PC shut down, I unplugged the only USB device I hade (mouse in rear port), powered off the power supply, waited 30 seconds, reversed everything and the PC booted with no problems.
Last night I received the same message, but after following the steps above nothing happened, except I noticed the mobo diagnostic LED flashing once every second. I then noticed a yellowish flash every second coming from the front USB port, which turned out to be a small spark. Upon further review of the USB slot and my floor:
Can you guess what is missing?
Found it (adapter for scale):
Spooky!
I'm not sure what happened, I built this machine last August and I've been very careful with my case. Not sure if the front USB assembly is replaceable but I'll see what Antec says.
Spooky!
