Its ALIVE!
pigdog2
Just did my first comuter build. Heres a pic of it running the WC system.
Here are some of the specs
AMD 4000+
PCP&C 510 sli PSU
Corsair XMS XLpro 1024 ram
swiftech 120 3a watercool CPU
eVGA 6800GT ( just one ATM)
seagate 160gb SATA HD
Plextor 716SA DVD/R
ASUS A8N-SLI deluxe
Blue Cooler Master wavemaster
I'm going to be adding a side window with duel 80mm LED fans and a uv light. Kind of scared to take a dremel to the nice blue side panel. I hope the paint dosent chip. Anyways I know its just stock but wasnt sure which forum would be the best to post this in. It was great fireing up the new computer for the first time. Its my Frankenstein complex bringing it to life.
DarkMonkey said:
Water cooled on your first build, eh? I'm impressed.
second!
def not bad for a first build, and with expensive components at risk to boot!
I went with the WC setup cause it gets so hot here even with AC,that I thought WC would be better. As for the risk? I figure what the hell live on the edge.
Can I suggest you go with a single 120mm fan instead? Get just as much air flowing through with half the noise of 2 80mm.
