Finally got my build done. Here are some observations.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103680
Seems to be a great little cpu. Too soon to tell, and I haven't started tweaking it yet
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128394
Tons of features, great quality, and has full overclock capability.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102849
Very large, plugging in power headers was a little scary to to it extending almost to the 5.25 cage. Performance is unknown. I haven't stretched it's legs yet.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
Seems to be solid so far. It's 2x4 12volt cable sucks though. It's to short. Because it's bottom mounted, I had no choice but to run it across the vid card and mobo to reach the port. It's a better top mounted psu.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
I had no issues what so ever installing this. Had no issues with my ram. But because of the AM3 retention frame, the hsf sits 90 degrees down. So the fan faces the vid card. I'm not thrilled about it, but I can see why they did it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119196
I'm thrilled with this case. It's high quality, cable management was a breeze and everything fit! It's also pretty quiet, even with the extra 120 I got mounted on the window for the vid card.
So far I'm pretty happy with everything. Thanks to those that provided input on this build.
