Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
As far as I know, it would be absolutely terrible as a gaming rig.
The reason is because almost all games are 32-bit. Itanium is 64-bit. When you try to run a 32-bit program on it, it slows down dramatically. Note that this does not apply to the "64-bit" desktop processors we have from AMD and Intel. Those are more of a bridge between pure 32-bit and pure 64-bit, meaning they perform well with both.
I believe there is one game out there now that can benefit from 64-bit. I don't know how that game would do on Itanium. But I know that all of the other games would do terribly.
What kind of rig are you looking at anyway? Itanium is meant for servers, which wouldn't have the graphics power needed to run games anyway.
WinXP does not support IA64. The versions of Windows that do support Itanium don't support DirectX. I think you'll also have a hard time finding a Windows video driver for Itanium that supports either DX or OpenGL anyways.
It might be possible to do gaming in Linux/Unix/Solaris/etc if you recompile the game source(s).
