It Works, Need More Advice
demetrics
First I want to start by thanking every one who helped out, by answer all of my posts. I just built my first PC.
AMD 3500+ 939
ASUS A8V Deluxe
480W TRUE BLUE ANTEC
ANTEC SILVER PERFORMANCE CASE
1 Gig of Corsair ValueSelect
NEC 16x DVD burner
160GB SEAGATE
Now I have a few questions. First I would like to know of any secure sites(spyware free) were I can go study up on how to tweak my computer for best performance? Does anybody have any advice on what I should do to tweak my computer? Next, I need some good anti virus software. I am willing to spend up to a 100$. I don't know if it is simply between Norton and Macifee? What is the difference between Norton Antivirus software and Norton Systems Works? Last I heard that SP 2 causes problems to your system and it doesn't work well with the 64 bit systems unless you know how to config it right. If this is true could I please get some advice and help on SP 2? How to config it and is it worth having?
Antivirus - Kaspersky or F-Secure, it takes them 6 and 8 hours respectively to get an update for a new virus. It is about 27 hours for Norton.
You also need a firewall. I would opt for a free version of Sygate.
I'd get the Symantec Client Security pack (NOT the Norton Internet Security pack) as it combines a good firewall with Symantec AV 9 Corporate.
cheers,
dave
