Okay guys, I just got handed a fun one. I still have yet to get all the details, but I wanted to get a head start since the cause or path to discovering the cause has not yet been established. Telnet sessions are timing out seemingly at random between client stations (XP Pro) and the telnet server at the main office. The timeout happens when they are sitting, not being used. When it works, it works just fine, so I am led to believe (nothing ruled out yet) that its something about the networking, not the software. Here are the facts (variables?), and I'll post more as they come in:
1. Old XP image didn't do this, new image does. I didn't create the image (was made before I started here) and to go back and trace what all is different between them would honestly be less usefull then to just recreate the image again. That probably won't happen though unless it is last last last resort. I only bring up this point to establish that this process has worked within the existing network structure in the past with no software changes. Well maybe a version has changed, I don't know and will find out.
2. Setting stations to a static IP seems to make the timeouts go away. Setting short DHCP lease times makes it happen more frequently and setting longer times make it happen less often. I'm thinking maybe when an IP expires is when its timeing out, I don't know and have yet to get my hands on a system to leave on next to me to be able to catch that. Thats first step for me.
3. We are a Novell 6.5 network using ZenWorks 4 for management and XP Pro for clients. We are using TCP/IP, not IPX/SPX. I was hired to be the MS guy (they have very few MS servers) and honestly don't have much familiarity with Novell or Zenworks (yet). Should have paid attention in high school when the netadmin was giving me the Novell certification courses for free to keep me from finding his network soft spots and installing Wolf3D and Wing Commander...
4. Uninstalling and reinstalling the latest Novell client (which is what we use) seems to take fix it, but I was handed that info from someone else and I always treat others troubleshooting as "not a guarantee". I'll assume its true for now though.
Now, I realize theres a lot more information thats needed to properly analyze this, and I'm going to be getting it. What I'm looking for are leads/similar situations that might point me in various directions. I used to be an escalation engineer for the 95/98 project for MS, so I understand that even something that sounds similar yet doesn't seem to be related can be the key to tracking down the "final answer." One more thing, serious IT Pros only need reply. I don't mean to be offensive, but I'd rather not get 10 posts like "make sure you get your windows updates" and "check your antivirus." Don't be afraid to call me on something if you think I may have missed it, but lets not pursue the obvious too far... Thanks, I'll be editing this post with new data as it comes in...
