Haven
- Oct 11, 2002
So my desktop is 4 years old, and it needs to be updated. I plan on doing general computer stuff, gaming being the major thing for the new desktop. I am not looking at overclocking, I want a board that will work with the Wolfdale processor right out of the box, so the IP35-Pro is out. I have a budget of around $1,400. Here is what I am looking at:
I plan on using my current case and optical drives and monitor, but I do need a new almost everything else. The current system is:
Did I make any major mistakes or misteps with the new build? I would like to know what I should change to get the best system I can get with my current budget and planning on it being decent for the next 3 years or so. Thanks!
One last thing, is the default cooler that comes with a retail processor good enough for cooling a system if you are not overclocking? If not, recomendations?
- Intel Core 2 Duo E8400 Wolfdale 3.0Ghz (45nm) $225
- Asus Maximus Formula ATX $260
- OCZ Gold 4GB DDR2 - 800Mhz (PC2 6400) Dual Channel $114
- Seagate Barracuda 7200.11 500GB SATA $120
- Creative Sound Blaster X-FI Xtreme Gamer Fatal1ty $136
- Logitech G9 $75
- Corsair CMPSU-550VX 550W power supply $100
- EVGA GeForce 8800GTS SSC 640-P2-N829-AR $310
- AMD Athlon XP 3200+
- Asus A7N8X-E Deluxe
- 1GB PC3200 Mushkin Level One matched set
- 300GB PATA
- BFG 6800 OC 128MB
