Issues with XFX 280x DD
ssnyder28
Hello,
I bought a XFX 280x double dissapation. The card seems to be working fine but I noticed that GPU-z sees the card as a Tahiti card and when i try to install amd catalyst it just sits on detecting system hardware when it is attempting to install the drivers. I ran valley benchmark too and got a pretty poor score a little over 1500 which seems really low for this card and it shows up as a 7970. Do I just have a bad card, is there a different method I can use to install a different display driver than amd catalyst?
A 280x is a 7970 (Tahiti). 1500 is a typical score at 1080p.
I don't see anyone with a benchmark score that low with a 280x, most I've seen in the 2200-2300 range. I see people getting a typical score of 1600 at 1440p not 1080p.
Also look at the screenshot:
Now the above is a very good score and is a higher end 280x than mine and is probably overclocked. Notice how it says its an r9 200 series
Here are my results:
Unigine Valley Benchmark 1.0
FPS:
37.5
Score:
1567
Min FPS:
13.3
Max FPS:
72.2
System
Platform:
Windows 7 (build 7600) 64bit
CPU model:
Intel(R) Core(TM) i5-2550K CPU @ 3.40GHz (3392MHz) x4
GPU model:
AMD Radeon HD 7900 Series 12.104.0.0 (3072MB) x1
Settings
Render:
Direct3D11
Mode:
1920x1080 8xAA fullscreen
Preset
Extreme HD
Powered by UNIGINE Engine
Unigine Corp. © 2005-2013
I would say something is wrong.
You have a R9 series card.... but it has a Tahiti core architecture...
You have literally a 7970. They changed the decals and that it.
I think the software just detects the series of cards, the guy that posted that said he has a 280x, I don't see any reason for him to lie and use a 290 lol.
