Issues with Striker II Extreme
vi0lation
Hi Everyone,
I've been reading these forums for several years now on and off, it is definitely my go-to place when I'm in need of good advise, reviews, etc. However I've run into an interesting problem - so hence my first post!
I've recently made the choice to upgrade my main gaming rig from a dying 4+ year old one to something I can actually play recent games on properly. Here are the specs:
Intel Core 2 Quad Q9650 Quad-Core Socket LGA775, 3.0 GHz, 1
Asus Striker II Extreme Socket 775 nVidia nForce 790i Ultra SLI Chipset Dual-Channel DDR3
Patriot NVIDIA Viper Series DDR3 PC3-16000 2000MHz 2GB (2x1GB) SLI Optimized Low Latency
BFG GeForce GTX 280 OC Nvidia GeForce GTX 280 (615Mhz) Shader Clock (1350Mhz) 1GB GDDR3
Seagate Barracuda (ST3500320NS) ES.2 SATA 3.0Gb/s 500GB Hard Drive
LG G-H20L-S10 /Black SATA LightScribe DVD-Writer
LG GGC-H20L Blu-Ray HD DVD Combo Drive
Corsair CMPSU-1000HX 1000W ATX EPS12V Power Supply
Looking back I don't think I would have bought the Striker II Extreme had I read all the Nightmare stories in regards to it so far. I've built many systems in my time - so assembling this guy was no different, well minus the fact that its not working :mad:
I am getting the famed "CPU_INIT" error code on the LCD poster of the motherboard. (This is with nothing plugged into the motherboard but CPU, and RAM - not even the vid card is in) This message appears even when the system is not powered on, simply with power to the motherboard this is constantly what the read out says. If I power up the CPU fans rev and so does everything else - but no POST, just CPU_INIT.
I've read several things now regarding this board and being really picky. Everything from:
a) Board not recognizing the CPU and the BIOS needs to be updated using an older CPU
b) RAM voltages are too low, and need to be upped to run the DDR316000 by using slower RAM to get into the BIOS.
c) RMA'ing the board back to Asus...
My current dilemma - I can get my hands on a E8600 Core 2 Duo to test the motherboard with to see if its maybe the motherboard not recognizing the Q9650. I've tried re-seating the chip several times all with the same result.
I can't get my hands on any "slower" DDR3 memory however (well short of investing a nice chunk of cash into something used merely to test once) I've read that the Striker II Extreme is DDR3 exclusively? So I assume I cannot test the mobo with a stick of DDR2 667? Or can I?
What would you guys suggest I do next? I will be testing my Q9650 in another motherboard in the coming days to make sure the chip is alright, I'm almost positive it is. But until then are there any steps I could take to try and fix the CPU_INIT hurdle this board seems to be giving?
Any suggestions would be appreciated!
Thanks in Advance,
-V
Thinking of maybe just tossing this board and going with the EVGA 132-CK-NF79-A1
Any thought or possible solutions anyone can think of?
Thanks!
I have the EVGA version of this board non FTW, and although I have had to RMA it once, EVGA was very good about everything. If you really dislike the mobo, I would suggest going with an Intel chipset (x48, P45) version rather then a Nvidia chipset route, that is unless you have to have SLI. I would be following my own suggestion if nehalem wasnt coming out before Christmas, as I will be a lab rat, I mean early adopter for that particular ball of wax.
My advice - rma the board. Get someone else to build your pc.
notes of interest -
Yeah, a buddy of mine had an asus board years back and needed a duron to get the motherboard to post. Needless to say - he had an athlon. Maybe that's why I have never bought an asus. I did seriously consider this board - but the evga 790i won.
At default settings, even a few tenths of a volt low on ram won't cause a CPU init error.
What are you, nuts? DDR2 and DDR3 are not compatible. You don't need slower ddr3. ddr3 will run UP TO the marked speed, including lower. This is the case with all ram.
No offense, but you're definitely in over your head. I don't think a different motherboard will help you. What do you think you should do?
Jeez, give the guy a break. Not everyone is 1337. Get the core 2 duo and update the BIOS and jump back on the learning curve.
notes of interest -
You do realize people come to this forum for help and insight right? Posts and attitudes like yours arent really neccessary and did absolutely nothing to help vi0lation. I am sure that you were born with all of your current computer knowledge and have had to never learn anything or once ask a question, right? So please take your negative attidue somewhere else and let people who are going to help vi0lation and maybe impart something other than the scum you find under your toilet which seems to be the only thing your post was good for. To vi0lation please disregard that post and continue to ask any questions you might feel the need to ask, as its the only way to learn.
It is obvious to anyone the op does not know the basics required to build and debug a computer system. He needs help, and you have not provided any. My comments are completely relevant and useful. Your comments contains nothing technically informative or useful for the op. Please continue with your uninformative opinions and irrelevant points of view. Keep the flame bait to yourself a**hat.
Yeah, maybe I was a little hard on him, but - The Striker II is NOT a beginner board. It can be difficult for even a semi-advanced builder to get stable. He's stuck with it now so the best alternative is to get someone whom is very experienced to build the system.
