Issues with Samsung SH-223F
Flogger23m
I am having some issues with my Samsung SH-223F/BEBN 22x Speedplus DVD/CD combo drive.
My issues are that it closes on me even though I did not press the close button. I am running no software in the background either. Sometimes it opens and then closes immediately, other times it waits a few seconds then closes. Sometimes it even closes itself before it finishes opening.
I have no disc in the tray when it does this, but is still does this when there are discs in the tray.
I have not changed any software for it in the past 6 or so months I have had it. It worked fine until probably a few weeks ago.
I am guessing like all CD/DVD drives, this one just broke. The tray looks very fragile, but I just wanted to ask and see if this is a common problem or not.
Is there any way to make sure it is a hardware issue?
And ss Samsung customer service any good? Will I likely be able to send it in for a new one?
its possible its going bad.. sounds like a firmware problem but there is no firmware update for that drive.. only other thing id say is when it opens.. grab the tray and pull it back could be that its skipping a tooth on the belt so that when it opens its triggering it to close the tray due to something being pushed against it.. or just replace the drive.. probably easier just dropping another 30 bucks to replace it then spend hours fiddling with the dang thing to get it working right..
hehe, thats happened with quite a few drives I've had. them damn ghosts keep playin with me. :p
If there haven't been any software updates that Vista could have accidentally auto updated, then I guess it is hardware.
I'll see if they will replace it. If not, that is $30 I really didn't want to spend. :(
Thanks for the replies.
