I'm try to authenticate with Yahoo's OAuth system.
I've successfully gotten a request token, launched a popup that forces a user to log in to their yahoo account, and approve my application. The next step in the process is to refresh the access token. Yahoo's documentation on this process is seen here. I'm running in to an error, "signature_invalid".
Line 117 in OAuthRequester.php is the following (bolded):
Here's the example of Yahoo's request:
Here's an example of one of my requests going out:
For the oauth_signature, it's the application secret + oauth_token_secret. I've tried all combinations of HMAC-SHA1/PLAINTEXT and concat'ing with '&' and '%26', all to no avail.
Does anyone have any ideas?
exception 'OAuthException2' with message 'Request failed with code 401: oauth_problem=signature_invalid' in /home/content/j/o/s/site/dev/oauth-php/library/OAuthRequester.php:117 Stack trace: #0 /home/content/j/o/s/site/dev/exchangeToken.php(55): OAuthRequester->doRequest() #1 {main}
$this->sign($usr_id, null, $name);
$text = $this->curl_raw($curl_options);
$result = $this->curl_parse($text);
if ($result['code'] >= 400)
throw new OAuthException2('Request failed with code ' . $result['code'] . ': ' . $result['body']);
Code:
https://api.login.yahoo.com/oauth/v2/get_token?oauth_consumer_key=dj0yJmk9NG5USlVvTlZsZEpnJmQ9WVdrOVQwazFPRUozTkc4bWNHozlNVE13TXprM01UUTBNZy0tJnM9Y29uc3VtZXJzZWNyZXQmeD1kNg--
&oauth_signature_method=PLAINTEXT
&oauth_version=1.0
&oauth_verifier=svmhhd
&oauth_token=gugucz&oauth_timestamp=1228169662
&oauth_nonce=8B9SpF
&oauth_signature=5f78507cf0acc38890cf5aa697210822e90c8b1c%261fa61b464613d0d32de80089fe099caf34c9dac5
Code:
https://api.login.yahoo.com/oauth/v2/get_token?oauth_consumer_key=dj0yJmk9S0tNZllnTXhhd01ZJmQ9WVdrOU9XVkpUVFZoTm5NbWNHbzlPRE0zTlRVek5qWXkmcz1jb25zdW1lcnNlY3JldCZ4PWQ3
&oauth_signature_method=HMAC-SHA1
&oauth_version=1.0
&oauth_verifier=taxyvk
&oauth_token=uakang3
&oauth_timestamp=1284601463
&oauth_nonce=674252535b2090cd50b6a1b5ed476e70
&oauth_signature=XXXXXXXXXXX54523a68c44856ae3d37bd&1570235115365e9ea16787fc2344fb07070e9000
