I have a box sitting here unused so I obtained a copy of Foldix so that I could put it to work. The system has a built in ethernet nic - for some reason this will not work regardless with foldix -it hangs on the DHCP.
I went out and obtained a nic card to put in the rig, just today I did this. Problem I have now is to tell it to use that nic card as it still looks for the Eth0 and not the Eth1. How would I be able to change this? Any suggestions would be helpful. Thanks.
