So I am building a new HTPC and was trying to speed up the process last night(all my remaining parts were coming in today and I will be out of town this weekend). Basically I was trying to use a move an old Vista installation over to an SSD drive and then upgrade to Windows 8 pro to get WMC. After having issues cloning the boot partition, I got the genius idea of just installing Vista from scratch using my new Windows 8 build. So I attached the new SSD, initalized it and started the installation without a problem. Everything went smoothly until the I upgraded the Vista Installation to Windows 8 pro (same as the existing OS on a different SSD), where I had to choose between the two at the booth screen and I chose the new installation to make sure WMC was ready to go.
Thinking all was fine, I shut down my computer and removed the SSD with the new Windows 8 pro install. Next startup my MB (P8Z77-V LK) didn't recognize my primary SSD (wasn't showing up in the SATA profile in the BIOS). After moving cables around to different SATA ports I was finally able to get to the boot screen.
However this is what I have to select every time.
I tried to do a repair and a refresh in the advanced options screen shown above and I got the following error.
So now I am at the point where I can access the the original windows 8 installation but it always goes to that OS selection screen and it is much slower then it used to be. From a hardware stand point I thought it was weird that some of my SATA ports would stop working and now when I shutdown, the power light stays on and the CPU fan keeps running.
Will I have to do a clean install to fix this? Thanks for any help!
