HalfJawElite
- Jul 2, 2012
Hey guys,
Recently bought an Intel RS2WC040 RAID card for my home ESXi server so that I can use it with pass-through to Server 2008 R2. My plans are to use it with Server 2008 R2 as a file server without having to create virtual hard drives to mount to the vm. My issue now is that ESXi hangs on boot up at the "loading module megaraid_sas" driver load. Should I try just re-installing the hypervisor to fix the issue or is there another workaround?
My servers specs are as follows:
Intel i7-3930K
ASUS P9X79 WS
8 x 8GB DDR3 1333 MHz Corsair XMS3 low profile
2 x 500GB WD Black's for running vm's
1 LG super-multi DVD burner (SATA)
1 Intel RS2WC040 RAID PCI-E card
Any solutions you know of will be much appreciated! So far I have only found reports of this issue and no guaranteed solutions.
UPDATE:
I have downloaded the newest drivers from Intel for ESXi 5.0 U1 but have been completely unable to install the drivers. Has anyone ever had any experience installing VIB files from a local datastore using the ESXi Shell interface?
Intel i7-3930K
ASUS P9X79 WS
UPDATE:
