Issue with 680i and a Mass Storage Device.
StaticlyCharged
Ok, so here's the deal. I've got my updated revision of the 680i Motherboard from eVGA (Love them btw). And it seems, my Neo35 Hard drive MP3 player (http://www.ssiamerica.com/products/neo35/), which docks in a IDE to USB cradle disconnects whenever I try to change something on the hard drive larger than say, 10MB. Drive just disappears from windows. Now, I've installed XP 32bit three times, and xp 64 bit once. Neither solved the issue, (fresh installs). it could theoretically still be the motherboard, but that would mean two motherboards with the same problem (as my original AR motherboard did the same thing). The eVGA techs thought it _might_ be the motherboards usb header, but no luck there. I have two (2) other USB devices (DVD+-RW) and (CD-RW) both work just fine. USB Thumb drives work without any problems as well.
So, i'm out of ideas. If it's a driver... I wouldn't know what type of driver to get for it. It's a Neo35. It's basically a Seagate hard drive inside a box, with an LCD display and some controls to sift through songs. It's one of the most amazing pieces of equipment i've ever used as it's been in use for two-three some odd years, and has had 0 problems.. until now.
I should mention, This device functions 100% on any other PC I own. Both USB 1.1 and 2.0. This is the strangest problem i've ever encountered.
Pretty much I'm out of ideas, and eVGA sadly, hasn't been willing to help me solve the issue. They basically said it's probably not compatible with the 680i chipset, and I should contact my hardware manufacture for updated drivers. And, I should point out the company that makes this product no longer makes it ;-). (Thus no longer supported). {not that i've ever had drivers for it in the past it's just a mass storage device}. Please, help me if you can :)
the nForce 3/4 had major issues with USB controllers and would drop the device off with delayed write failed.
I ended up running USB cards with all my nForce machines as it irritated the nuts off me.
Do you have any other issues with it at all with USB devices?
No! that's what's driving me nuts! Is that it's just dropping the one device! Thank god someone else had a similar issue, if that's all it is, I'll just buy a USB card. I do however wish eVGA would acknowledge this as a known unfixable issue :(
