So I picked up a Routerboard 750 to try out since it was pretty much dirt cheap ($40) and ipv6 compatible.
Although after punching in the basic settings, I've come across quite a strange issue. First of all it does not seem to like my Cisco 2900 XL switch, when I have it plugged into the lan it won't pass packets at all. No biggie, upgrading to a gigabit switch later, and I only have a few items plugged in anyways.
The weird issue is when I try to set a static IP on the wan port. Right now I have the router plugged directly into my cable modem (Motorola SB5101 on Cox Communications.) It works great when I let it run with the DHCP address assigned by Cox, although when I try to set the static IP address that i've been assigned by cox, I see about 50% packet loss, if not more. I know it isn't the address, since I've been using this address for quite some time on other devices with no issues.
Any help I can get on this will be great, I tried the MikroTik forums, although an admin has to approve your first message, which hasn't happened even though I tried to post over 24 hours.
