paperwastage
- Jul 12, 2009
Right now, my friends and I are living in Baltimore 21210...
Locally, there is Comcast(12Mb/2Mb) and Verizon DSL(1Mb/384kb).
We actually have 3 apartments among 8 people, around 13 devices(mix of b/g/n devices). Two of them are next to each other(dry wall separating the apartments), and the third one is in the building next door (about 75 feet away, maybe 4-6 walls plus exterior wall). The modem is most likely put in the 2-apartment area.
I currently have 2 (crappy) Netgear/Verzion-branded b/g routers that lag under multiple devices, so that won't work... also had a Netgear N-router that i bricked trying to update to DD-WRT
Should I go with a really good residential N-router, or look for a used Cisco Commercial router?
1) try to work with just one really good router in the 2-apartment positioned as best as possible for the third apartment. Wireless N with b/g fallback, better range but no speed increases
2) try to work with one really good router in the 2-apartment, directional antenna N-link with an access point in the third apartment(so this is like the 'backbone'). I will use my existing 2 routers to create hotspots in each of the two areas.
