Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have a few of the no-vibes, and they're very good, but very expensive ($30 per drive) as compared to just buying tailoring elastic ($2 per drive) and suspending them.
You have obviously never seen what 12 months inside a computer case does to a rubber band.
Et al. I'm not looking for an aftermarket solution. Are there no other case manufacturers that include any kind noise dampening solution in their cases to minimize hard drive vibration.
