On the VNXe you can only have 1 iscsi server per SP, and you can only have two NICS assigned to the iSCSI server.
Two Questions:
If I have two nics bound to two vmkernel ports, whats the max paths that I can have per volume/LUN? Would it be 4? I have a weird scenario where my first host sees 4 paths per volume and my second host only sees 2 (physical setup /connectivity are the same)
Also, does there need to be connectivity between the physical switches that i have?
Two Questions:
