So I am a mad tinkerer like most users here, and currently have an all-in-one virtualized storage system (thanks to napp-it).
My current storage system is spec'd below:
Semperon 140
8gb ram
4x 2tb 5400 rpm spinpoints, connected via onboard sata controller
Right now I use said parts to not only run the storage system, but also two virtualized 2003 servers w/ exch 2003 and sql 2005. It boots slow, but runs adaquate.
This question my blur the lines between the Virtualization and storage forums but here goes:
I plan to repurpose my storage system into JUST storage. Blow away the virtualization, add an ssd for zil/l2arc, and just run a free OS/ZFS/iSCSI solution.
With this storage setup, would you think I could host 4x Server 2008 R2's, with Exch 2010 and SQL (both redundant/clustered/etc)? They would be running on some nice mini servers built with sandy bridge xeons, 16gb ram, etc (ESXi 5).
The I/O loads are rediculiously low.. two users on exchange.. with a total of maybe 10 new emails per day. SQL backend for a website that gets less than 100 hits per day. File sharing would also be done, but just stuff like mp3's. No Bluray streams or anything.
Looking at bonded intel gigabit nics all around and a cisco gigabit switch. A dedicated iSCSI level switch is out of the budget range.
THis is all just for my home... but lets call it a test lab so I can justify it
Semperon 140
8gb ram
